Activity Forums Apple Final Cut Pro Legacy I can’t play back ProRes whit out frames drop
  • I can’t play back ProRes whit out frames drop
    Posted by Morten Raarup on November 16, 2007 at 11:18 am
    I can’t play back ProRes whit out frames drops. The raid play back uncrompressed
    HD whit no problems.
    System:
    Octo 3 Ghz MacPro ( 4 GB RAM)
    Kona 3, whit lates driver
    AVID VIDEORAID
    ATTO ULD5
    OS X 10.4.11
    FCP 6.02
    What can I do to fix this ?
    Morten Raarup
    On Off Line Postproduction
    Copenhagen, Denmark
    Zak Mussig replied 18 years, 9 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    November 16, 2007 at 1:45 pm
    How was the Avid Videoraid formatted? With the Mac Drive utility?
    Jerry
  • Morten Raarup
    November 16, 2007 at 2:24 pm
    Yes – and it runs whit uncompressed HD whit out dropframes. So it is a ProRes problem so how.
  • Jerry Hofmann
    November 16, 2007 at 3:19 pm
    I think you shouldn’t have a whit of problems… (I can run ProRes files from a firewire 800 drive) Dropped frames might be caused by a quicktime problem maybe… might reinstall it.
    Jerry
  • Zak Mussig
    November 16, 2007 at 8:06 pm
    I’ve been dropping frames in HDV today on a Mac Pro, so I think the issue may be with Apple’s updates from yesterday. That’s all that’s changed on my system since yesterday when it ran just fine. I also started using Time Machine (only for the system drive), so that could just as easily be the culprit.
    Zak
