Activity Forums Maxon Cinema 4D i can’t locate tools
  • i can’t locate tools
    Posted by Roger Heyward on June 19, 2014 at 3:35 pm
    I’ve been going through tutorials on C4D, and I feel like I’m learning a lot, but I must have missed something or hit a key that I shouldn’t have, bc I can’t seem to find any tools like the Extrude, Knife, etc. I understand that there are modes like Point/Edge/Polygon, and I understand there are parametric objects that can be made editable via the Make Editable button, but it doesn’t matter what I do with these buttons. I still can’t seem to find any tools other than the Move, Scale, Rotate, and Selection tools. I’ve tried to right-click in the Viewport, with objects selected and unselected. I’ve tried looking in Main Menu/Tools and Main Menu/Mesh. I’ve tried deleting my preferences folder, but that doesn’t solve me problem either. I hope someone can help. Thanks.
    Doland Ruiz replied 12 years ago 4 Members · 4 Replies
  • Ronny Traufeller
    June 19, 2014 at 4:08 pm
    can you maybe just reset your layout to standard?
    then it should be all there..
    window-> costumizaion-> layouts-> standard
    the tools can be found in
    mesh-> create tools
    RRR
    traufeller.de
  • Darby Edelen
    June 19, 2014 at 4:16 pm
    [Roger Heyward] “I’ve tried to right-click in the Viewport, with objects selected and unselected. I’ve tried looking in Main Menu/Tools and Main Menu/Mesh.”
    The Knife and Extrude tools are in the Mesh > Create Tools sub menu.
    If you are using Cinema 4D Lite then you don’t have access to these (and other) polygon modelling tools.
    Darby Edelen
  • Roger Heyward
    June 19, 2014 at 4:37 pm
    I am using C4D lite, so that must be it. Thanks.
  • Doland Ruiz
    August 13, 2014 at 11:01 pm
    Does the Lite version also not include the Symmetry Object tool? Trying to do the tutorials online when the interface doesn’t match is a real pain. Haven’t found one tutorial that matches mine. Using R14 Lite in After Effects CC.
