Activity Forums Adobe After Effects I can’t get Knoll Unmult Plugin to show install in CS5
  • I can’t get Knoll Unmult Plugin to show install in CS5
    Posted by Cary Tobey on January 4, 2011 at 4:23 am
    I am using a MacPro 10.6.5 running After Effects CS5.
    I have made several attempts to install the free Knoll Unmult plugin and can not get it to show up anywhere under effects.
    I assume there is something silly and easy I am not doing so could someone please outline the process of getting the plugin to appear in CS5?
    Thank you in advance
    Jonathan Perkins replied 14 years, 5 months ago 6 Members · 11 Replies
  • 11 Replies
  • John Cuevas
    January 4, 2011 at 1:54 pm
    Have you upgraded to the 64 bit version? It can be found here: https://www.redgiantsoftware.com/products/free/
    Johnny Cuevas, Editor
  • Cary Tobey
    January 4, 2011 at 3:13 pm
    That was it. I had been to that very download site several times and just totally missed the the drag-down menu so I was getting the old version every time.
    Thank you!!
  • Ra-ey Saleh
    April 12, 2011 at 11:24 pm
    Real newb question, so apologies.
    I have the 64bit version for CS5, but don’t know ehre to put the plugin.
    Does it matter which plugin folder I put it in, i.e.:
    Effect
    Extentions
    Format
    Keyframe
    Thanks in advance,
    Ra-ey
  • Ra-ey Saleh
    April 17, 2011 at 9:57 pm
    I have asked around and none of my mates have been able to get this to work in 64bit CS5. Has anyone here managed it?
    Cheers,
    Ra-ey
  • Kenn Baynard
    September 1, 2011 at 4:42 am
    Any update to this? I just received a graphics package that requires Unmult and I can’t get it to show up.
  • James Cook
    September 19, 2011 at 10:44 am
    I’m in the same boat. any news on this would be greatly appreciated.
  • Jonathan Perkins
    February 9, 2012 at 5:18 pm
    I found this on the red giant website in case anybody is still stuck…
    Unmult should be located here: ApplicationsAdobe After Effects CS5.5ScriptsScriptUI Panels
    Here are some FAQ’s that should be able to help
    Mac:
    https://www.redgiantsoftware.com/support/faq/product-specific/knoll-light-factory/225/
    Windows:
    https://www.redgiantsoftware.com/support/faq/product-specific/knoll-light-factory/226/
    Contact our support team if you need further assistance.
    Thank you,
    Kaylinn
    I have mine is located at /Library/Application Support/Adobe/Common/Plug-ins/CS5/MediaCore/UnMult-64.plugin and seems to be working fine…
    JP
  • Ra-ey Saleh
    February 9, 2012 at 11:11 pm
    Thanks for the info, very helpful.
    Ra-ey
  • James Cook
    March 13, 2012 at 4:48 pm
    Hi Jonathan
    thanks for the info. the issue I’m having though is with CS5.5 and wether there has been an update to unmult or not.
    I’ve tried the 64bit plugin in all the relevant places, UI scrips, plugin folders etc. It still doesn’t show up in AE.
    If anyone has had any luck with CS5.5 pleas elet me know. I could be missing something very simple, woods for trees etc.
  • James Cook
    March 13, 2012 at 5:01 pm
    All is well. At last.
    Thanks all for your help. After frantically trying it in every conceivable place it works.
    Even though my CS5.5 still says there are multiple copies of unmult on my machine, which there aren’t, it is finally working. It is the 64bit unmult plugin dropped into the mediacore folder. But in CS5.5 it shows up as a 32bit plugin but it works and that’ll do.
