Activity Forums Maxon Cinema 4D i can’t get “center” to center anything… or do anything at all
  • i can’t get “center” to center anything… or do anything at all
    Posted by Joe Carusoe on February 10, 2007 at 5:15 am
    in version 10.
    i make a null, put a few objects in it, and then try to center the axis with the function: “center”.
    nothing happens.
    what gives?
    Joe Carusoe replied 19 years, 6 months ago 2 Members · 2 Replies
  • Paul Coull
    February 10, 2007 at 5:53 pm
    Select all your objects inside the null object.
    Select ‘function/center’.
    Now in the attributes window select the ‘options’ tab.
    For this example set the x axis to middle.
    Then under the ‘tool’ tab select ‘apply’.
    This should centre all the objects.
    grafxflow
    grafx that flow!
  • Joe Carusoe
    February 20, 2007 at 4:17 am
    thanks!
