I can’t figue out how to render 1080p MPEG-2 with PCM audio.
Wayne Waag replied 9 years, 3 months ago 5 Members · 14 Replies
Wayne Waag
May 15, 2017 at 2:31 pm[harry singh]
AFAIK, there is no way to do this inside of Vegas.
You can use TMPGEnc’s Mastering Works 6 to accomplish this. Here are a couple of screen shots. The first is from the GUI.
And here is the resulting media info screen shot.
You can also adjust the bitrate to whatever you chose.
Alternatively, you could use the other app that I mentioned in a previous post in this thead–their Smart Renderer.
Good luck.
wwaag
John Rofrano
May 15, 2017 at 2:42 pm[harry singh] “…can you please guide how to render 1920x1080p 25 frames with 80mbs render in mpeg .ps in vegas pro ?”
I agree with Wayne, Vegas Pro doesn’t support this. The closest is to use the MainConcept MPEG-2 encoder with the Program Stream PAL template and you can change it to HDV and get 60mbps but that’s as high as the bitrate goes.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com -
Harry Singh
May 25, 2017 at 10:29 amthnx dear. for your support.
i think first i have to render mpeg2 1920×1080 p with 80mbps
after need to convert in TMPGEnc Video Mastering Works .Regards
HarryRegards
harry -
Wayne Waag
May 25, 2017 at 2:13 pmTo make sure that you achieve the best quality, you should either frameserve or render from Vegas using a lossless codec such as utVideo or Magic YUV.
wwaag
