Activity Forums Adobe Premiere Pro I can’t drag in a full sequence
  • I can’t drag in a full sequence
    Posted by Christian Szokolay on January 1, 2017 at 10:57 am
    So basically every time I have “sequence 1” where some video and audio clips are synced and cut and I import it into “sequence 2” Premiere will only bring in a section of “sequence 1” into “sequence 2”. I then have to drag “sequence 1” several times to the end of the timeline so I can see the entire “sequence 1” within “sequence 2”. Is there some setting Premiere has that tells it to only import a section of a sequence? It feels like I have invisible in and out points set by defautl or something. Any help will be greatly appreciated.
    Thank you,
    Chris
    EDIT: So I have found that manually setting in and out points within a sequence accomplishes what I’m trying to do but it’s still weird that by default Premiere won’t import the entire sequence.
    Duke Sweden replied 9 years, 8 months ago 3 Members · 2 Replies
  • John Pale
    January 1, 2017 at 6:07 pm
    Use the Media Browser to open the sequence in the Source Monitor, then select all, cut/paste into the destination sequence
  • Duke Sweden
    January 1, 2017 at 8:06 pm
    I did have that happen to me as well right after I upgraded to cc 2017 but, like all the other quirks, it suddenly stopped.
