Activity Forums Adobe Illustrator I can’t do anything without a message coming up to revert.
  • I can’t do anything without a message coming up to revert.
    Posted by Anastasia Thomas on November 27, 2009 at 1:42 pm
    While in Illustrator, as soon as I click on anything, a message keeps coming up to REVERT to saved version. When I click on cancel, it keeps coming back and won’t go away until I click on revert, then all my work gets lost. Is there any way to fix this problem?
    Stuart Gill replied 16 years, 9 months ago 2 Members · 1 Reply
  • Stuart Gill
    December 1, 2009 at 10:31 am
    Is this happening in one file or all files?
    If it is only one file that is causing the problem, try copying the contents into a new file and continue using the new one.
    If it is all files, try deleting the AIPrefs (Adobe Illustrator Prefs on Mac) file by closing Illustrator and going to:
    On Windows – Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS* Settings (or your version of Illustrator).
    You will need to show hidden files in order to see the Application Data folder.
    On Mac – Open the Finder and then go to Go > Home > Preferences > Adobe Illustrator CS* settings (or your version of Illustrator).
    Once you have deleted it, restart Illustrator and see if it happens again.
