Activity › Forums › Adobe Premiere Pro › I cannot import AVI or MPEG2 files
Posted by Stuart Devlin-gray on August 6, 2007 at 8:14 amHi can someone please help me I cannot import MPEG2 files as premiere pro does not recognise the files & when I try import AVI files Premiere crashes saying it has encountered a serious problem ?
Rottweiler replied 19 years, 1 month ago 5 Members · 6 Replies -
Steven L. gotz
August 6, 2007 at 7:50 pmDo you have Premiere Pro 2.0 or higher? Are you trying to use AC3 audio which is not supported without a workaround?
Steven
Stuart Devlin-gray
August 7, 2007 at 7:44 amThank you for replying, I am using premiere pro cs3 I will check the codecs and audio type, can someone please recomend what is the best programme for converting MPEG2 to AVI. Again thank you very much
Stuart Devlin-gray
August 7, 2007 at 8:42 amDoes anyone know if there is a way to import MPEG2 into premiere CS3 so I don’t need to convert the file at all ?
Blast1
August 7, 2007 at 6:55 pmTwo questions:
1. do you have the tryout version?
2. is the avi you are trying to import divx or a similar format? -
Rottweiler
August 23, 2007 at 5:53 amYou can import mpeg2 files by useing (Mpeg Pro HD)plugin for premiere.it is made by mainconcept.
