Activity Forums VEGAS Pro I can not project guardr
  • I can not project guardr
    Posted by Aroa Cocera on January 16, 2010 at 12:13 pm
    Hi! Such?
    I am telling you…
    I use the SonyVegas 9 , Version 30 days
    I started to do my project, And when I put it… To open later..
    Can not. It's like SonyVegas not acknowledge that it is their program.
    Rendered against violence that had echo, And worked perfectly.
    The problem is.. I can not turn off the pc.. Because if he loses his job and I can not
    Continue where I left.
    With the SonyVegas 8 , I had no problem.
    I can do??
    Thanks 😀
    Terry Esslinger replied 16 years, 7 months ago 2 Members · 1 Reply
  • Terry Esslinger
    January 16, 2010 at 6:02 pm
    Are you trying to open a .veg file? Apparently you say that you cannot save your project as a .veg file and reopen it later? Are you creating your project in V8 or V9? Are you trying to open it with the same program? Have you tried making sure that .veg files are associated to open with the version that you want it to – apparently V9?
