Activity › Forums › Adobe Premiere Pro › I can not hear audio on import of a m2t file.
  • I can not hear audio on import of a m2t file.
    Posted by Alvin Lowery on November 13, 2012 at 3:49 pm
    I can not hear audio on import of a m2t file. I can hear the audio in the VLC media player but I can not hear it when I import it into Adobe Premiere CS5.
    Mike Molenda replied 13 years, 10 months ago 2 Members · 1 Reply
  • Mike Molenda
    November 13, 2012 at 6:31 pm
    Sometimes it can take a while, especially if you’ve got a long clip. When you import the clip, Premiere has to do things like generate waveform data, index the clip for searching, etc.
    This happens in the background, so you can start editing your clip immediately after import, but sometimes things like conforming the audio will take a while. If you quit out of Premiere while this is happening, then the process is terminated until you relaunch the application.
    I generally give the system a few minutes to process after an import. There should be a small yellow progress bar in the corner of the screen indicating the status. This is time well-spent naming your clips, sorting them into bins, etc.
