Activity Forums Adobe Premiere Pro I can no longer insert entire sequences into other sequences. Why?
  • I can no longer insert entire sequences into other sequences. Why?
    Posted by Tom Clasman on July 9, 2017 at 3:16 am
    I’m experiencing a difficult to solve problem that seems to have started to happen out of the blue.
    I am trying to insert a pre-made sequence, into my ‘Main’ sequence. I have done this so many times before. But now, all of a sudden, I cant drag the sequence into a track of the ‘main’ sequence, like a block or separate videoclip – which is what I have always done. Instead, what happens when I grab the sequence I want to insert, and drag it in over the main sequence, is that all the clips inside the separate sequence gets copied from the separate sequence into the main sequence as separate objects. Not as a whole sequence, like I’m used to, and want.
    I don’t know why this has started to happen, I haven’t changed any settings, updated or installed anything onto the computer as far as I can remember. I have reviewed the settings in both project and the Premiere application but I cannot seem to locate if there is a problem with some setting in there. Also, I’ve made all this on my own computer, so it’s not a question of bad references or missing files or parts. I am using PP 2015.
    I could use some help understanding why this is happening, and how I can return to being able to paste a separate sequence into the main sequence like one whole block again.
    Thx for any comments
    Tom
    Tom Clasman replied 9 years, 2 months ago 3 Members · 3 Replies
  • Ann Bens
    July 9, 2017 at 7:31 am
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Duke Sweden
    July 9, 2017 at 10:55 am
    Like Ann “said” ????
    This happened to me once and I would swear on my life I never touched that button, but it happened.
  • Tom Clasman
    July 9, 2017 at 1:13 pm
    Ohh ????, it was THAT simple? Christ …
    They say the first thing you go blind on, is your eyes. 😛
    Thank you Ann.
