Activity Forums VEGAS Pro I can *almost* create the effect I’m looking for
  • I can *almost* create the effect I’m looking for
    Posted by Bojun Gunn on January 30, 2014 at 7:19 pm
    I’m looking to recreate an effect which is fairly simple. It’s achieved by moving the colour layers separately. I’ve figured out a method of doing that – duplicating the clip into 4 tracks, using Channel Blend to make the top 3 R, G and B, and then setting them to Screen. Then simply move the tracks and the colours will move independently.
    The problem is that while I’ve managed to make some pretty effects with this, I can’t make it look *exactly* as I’d like it to.
    So here’s an example of the exact effect I’m trying to recreate: https://www.imagebam.com/image/2d13b8304987909
    And here’s the closest I can come: https://www.imagebam.com/image/0af406304987903
    As you can see, it’s much more washed out and the colours aren’t as defined. The thing is, though, that no matter the blend mode I have the tracks in (and it doesn’t have to be Screen to work) it ends up washed out like that and, if I turn the brightness down, the shifted colours become more muted, too. Alternatively, turning the brightness down on the bottom layer does nothing. What I’m looking for is to be able to have it come out like the first picture – without the darker colours washing out, but with the shifted rainbow colours being bright and saturated.
    I’ve tried about everything I can think of, so it seems like it’s time to ask. If you were looking to achieve the effect in the first picture, how would you go about it?
    Bojun Gunn replied 12 years, 7 months ago 2 Members · 3 Replies
  • Micah Wolf
    January 30, 2014 at 8:21 pm
    Assuming you are doing this in After Effects, try adding an adjustment layer over top all of the layers. Once you have done that adjust the levels, contrast and brightness of the adjustment layer. Good Luck!
    Micah
  • Micah Wolf
    January 30, 2014 at 8:23 pm
    Sorry I just realized this was in the Vegas forum and I know nothing about Vegas. Maybe try doing everything I said to an empty text layer.
  • Bojun Gunn
    January 30, 2014 at 11:57 pm
    I could render it down, but that’s very time-consuming (particularly as I’m looking to make this effect about 3-6 frames long in total, but happening more than once a second), and I don’t think I could make the white less bright without also muting the colours.
