Activity Forums VEGAS Pro I am having multiple Error shut downs in project
  • I am having multiple Error shut downs in project
    Posted by Don Cobble on April 13, 2011 at 7:40 pm
    I am having mutiple error shut downs and I am taking screen shots of the error messages what do i do to find out what they mean and they are all diffrent. Example:
    unmanaged exception (0xC0000005)
    vegas100k.dll
    ntdll.dll
    wdmaud.dll
    This is just three it has happened about 15 times in 2 days.
    any ideas
    plz
    PC
    I7 2.8 Ghz 8GB Ram (Over Clocked to 3.35Ghz)
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas Pro 9 32bit & Vegas Pro 9 64bit & Vegas 10 32bit & Vegas 10 64Bit
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Don Cobble replied 15 years, 4 months ago 2 Members · 8 Replies
  • 8 Replies
  • Stephen Mann
    April 13, 2011 at 8:41 pm
    “unmanaged exception” is all you need to know. This usually means that the O/S has received an error code from a DLL or driver that it wasn’t expecting, and so it doesn’t know what to do with it.
    The culprit is almost always a driver problem. I would look first at the video driver.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Don Cobble
    April 13, 2011 at 8:54 pm
    As in the Nvidia quadro 4000 video card driver? should I roll it bak to an earlier driver?
    PC
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Stephen Mann
    April 14, 2011 at 2:34 am
    I would also try rolling back the overclocking. If you’ve tuned the overclocking to the edge of failure you are only asking for problems.
    Steve Mann
    http://www.mmdv.com
  • Don Cobble
    April 15, 2011 at 3:07 pm
    I am still crashing now close to 30 times on one project _ i tried to undo over clock. meaning i think i did it ok. I have removed hardware. I had a blackmagic intensity pro card installed also with my Qudro 4000 so i could have a 3rd monitor – I took that out last night hope that might have been it? Or maybe my quadro has a problem? it happens alot when use an eye dropper for anything. Dont know what else to do.
    any ideas i am open.
    PC
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Stephen Mann
    April 15, 2011 at 7:35 pm
    I’m still thinking video driver.
    Download the latest driver from the PC manufacturer or whomever made the display adapter card.
    Steve Mann
    http://www.mmdv.com
  • Don Cobble
    April 16, 2011 at 12:17 am
    I did download the latest video driver, but still problem – I have been on the phone with sony tech support – no success so far – i am beginning to think u may be correct about the video driver problem but maybe its my card i have the Quadro 4000 – still under warranty, but I dont know. Sony is having me do a clean uninstall and install i am baking something up then will try it?
    Thank you for your efforts
    don
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    Intensity Pro
    3-4 TB HD
    Camera
  • Stephen Mann
    April 16, 2011 at 12:39 am
    Sony tech support can’t help you fix your computer. I would go all the way back to a fresh install of Windows. Buy a new 500Gb hard disk, do a fresh install of Windows and Vegas – don’t forget those device drivers. If you *still* have a problem, then start suspecting hardware.
    Steve Mann
    http://www.mmdv.com
  • Don Cobble
    April 16, 2011 at 12:50 am
    will give it a shot i was wanting raptor drive for my OS so now the chance. I will let you know if that cured me>
    THANK U
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    Intensity Pro
    3-4 TB HD
    Camera
