Activity Forums Maxon Cinema 4D HyperNURBS subdivision renderer settings not working?
  • HyperNURBS subdivision renderer settings not working?
    Posted by Rob Ainscough on May 5, 2010 at 5:17 am
    I’m probably missing something, but in C4D 11.5 (core) if I set the Subdivision Editor = 2 and set Subdivision Renderer = 6 on a HyperNURB and then render, it renders the object as is (aka value of 2) and not the higher geometry 6 setting??
    Is this a bug or am I just missing something?
    Thanks, Rob.
    Brian Jones replied 16 years, 4 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    May 5, 2010 at 2:13 pm
    The render setting only applies to rendering in the picture viewer. If you render in the editor window you get the subd level specified in the editor setting.
  • Brian Jones
    May 5, 2010 at 10:29 pm
    FWIW if you really want the detail in the Editor Window renders you can also select ‘Display/Use Render LOD For Editor Rendering’ which will give you the same detail as the Picture Viewer but it’s the slower too.
