Activity Forums Maxon Cinema 4D HyperNURBS isn’t working..?
  • HyperNURBS isn’t working..?
    Posted by Ilya Osovets on April 25, 2012 at 9:03 pm
    Maybe its something simple Im over looking but when I add the HyperNURBS and place say a cube in it. Nothing happens.
    I have seen time after time in tutorials and examples by placing something in the HyperNURBS it should round the object. But I get nothing.
    Am I over looking something?
    C4D Studio R13
    Ilya Osovets replied 14 years, 4 months ago 4 Members · 6 Replies
  • David Biederbeck
    April 26, 2012 at 1:17 am
    Can you give me a screen shot?
    I just tried it myself to see if it needed to be broken into a poly, and here is what I got.
  • Ilya Osovets
    April 26, 2012 at 4:33 pm
    Hey thanks for the reply,
    I did what you did with no result.
  • Ilya Osovets
    April 26, 2012 at 4:42 pm
    Wait!!!
    After render I see it in working…. I thought I watched tutorial after tutorial where one would apply it and see the result before the render?.
    Well at least I’m getting somewhere. Thanks!
  • Tim Shetz
    April 26, 2012 at 9:44 pm
    Hypernurbs have a setting for editor and renderer. If the editor setting is not set right, you will not see the results until you render.
    __________
    Tim Shetz
    c4dtraining.com
  • Darby Edelen
    April 27, 2012 at 5:24 am
    In your viewer panel go to the “Filter” menu, it’s between “Options” and “Panel,” and make sure that there is a check mark next to:
    √ HN Mesh
    I think that’s most likely your problem.
    Darby Edelen
  • Ilya Osovets
    April 30, 2012 at 6:42 pm
    Thanks guys, your suggestions solved my problem with seeing the HyperNURBS in action.
    best!
