Activity Forums Maxon Cinema 4D Hypernurbs alternative?
  • Hypernurbs alternative?
    Posted by Emmet Reddy on November 18, 2010 at 4:30 pm
    Hi i have a load of small squares that i want to smooth out very slightly just take the edge off, i can do this with hypernurbs and cut a few edge loops but i was hoping somebody knows a much quicker way of doing this do a lot of small squares.
    In general if any one knows of a good plugin that will just take the edge off objects
    other than Hypernurbs and then having to weight the hypernurbs etc to get the desired effect i would appreciate it.
    I hope i am clear thanks Emmet
    Emmet Reddy replied 15 years, 10 months ago 3 Members · 3 Replies
  • Rob Pierce
    November 18, 2010 at 6:49 pm
    You can add a fillet to the cube in the attribute settings without even having to make the cube editable.
  • Les Nemeth
    November 18, 2010 at 7:28 pm
    Or if it’s editable, you could try Smooth Shift.
  • Emmet Reddy
    November 19, 2010 at 10:38 am
    Thanks Guys that smooth shift should do the trick
