Hyperlinks change from InCopy CS4 to InDesign CS4
We’re having a problem with the hyperlinks changing when importing InCopy text into InDesign. While the links all check out in InCopy, once they are imported into InDesign the first two links in the document are changed to our editor’s email address and the rest of the hyperlinks are incorrect because they have been shifted down two hyperlinks. The original text is edited in Word, but all the links work there, and they also work after being converted to InCopy.
Any ideas?
