Activity › Forums › Storage & Archiving › HyperFS SAN vs. StorNext ?
  • HyperFS SAN vs. StorNext ?
    Posted by John King on January 4, 2011 at 4:33 am
    Anybody used Falconstor’s HyperFS SAN software yet?
    I got a demo of the SAN software and want to get an idea of what to expect as far as performance in multi-stream reads and writes as well as single stream benchmarks.
    Also anybody running StorNext with similar specs? What benchmarks are you getting for comparison?
    My environment is only HD, no film. I have 4 Final Cut Edit bays for HD and a 4 windows servers including a DVS Clipster for DPX. Only 2 edit bays are expected to be editing at the same time as Clipster is operating. So pretty much 3-4 streams simultaneously.
    Specs:
    2x 8Gb Qlogic 5800 series switches
    2 MDC’s running RedHat and using dual port QLA2560 8Gb hbas
    4 Windows clients using Atto 8Gb dual port cards
    4 Mac 10.6 clients using Atto 8Gb dual port cards
    No MP right now as I want to get good single port marks.
    Hitachi AMS-2300v2 dual controller storage with 48 drive SATA arrays and SAS metadata luns. 8 ports to the switch, 2 zoned for metadata only and the other 6 for data.
    Luns are:
    4 data luns = 10D+2P with 2TB SATA drives , 256K chunk
    The 4 luns are balanced across 2 controllers and each has its own 8Gb port.
    1 metalun = mirrored 15K sas drives, 64K chunk
    I set up 1 volume group with HyperFS with four 17TB luns in a stripe using 1MB stripe and 1 MB allocation.
    Preliminary test are showing odd results for Mac OSX. Using AJA’s notorious system test to get a quicky reading. Controller write cache enabled on metadata servers.
    1Gb file size, 1920×1080 10-bit framesize
    Windows is getting me 484 W / 376 Read.
    Mac is getting me 360 W / 290 Read.
    Brian Adams replied 14 years, 11 months ago 4 Members · 4 Replies
  • Caspian Brand
    January 5, 2011 at 11:33 pm
    Not that this will necessarily change your results, but I would suggest using a larger file size in your AJA tests, say 8GB or 16GB to try to make sure that test file puts a more constant hit to your storage.
    -Caspian
    Product Specialist
    Studio Network Solutions
  • Steve Modica
    January 14, 2011 at 1:55 pm
    The Aja test is not a good representation of FCP traffic. It uses a smaller IO size and it’s not Async IO either. FCP does larger IOs in parallel.
    Steve Modica
    CTO, Small Tree Communications
  • John King
    January 21, 2011 at 10:44 pm
    Yeah,
    I switched to using the compiled for mac version of lmdd.
    I also used Brite systems benchmark, which is awesome, btw.
    I was pinging it pretty hard with iometer as well from the windows side.
    HyperFS seems to fly with a Windows environment but I’m running into performance issues on the Mac client. Its still fast, but significantly less than a linux or Windows box on the san.
  • Brian Adams
    October 19, 2011 at 4:17 pm
    John, what that that “Brite” benchmark, and where can I get it?
    Brian
