Activity › Forums › Blackmagic Design › HyperDeck Studio Pro Capture
Posted by Mark Wilson on April 15, 2014 at 2:09 amCan four video streams be captured simultaneously to SSD drive? Also can I route and assign the audio to each of the four video streams in sync?
MarkMark Wilson replied 12 years, 5 months ago 2 Members · 4 Replies -
Chad Pearson
April 15, 2014 at 9:07 pmNo. The Hyperdeck’s only have 1 input. The other 3 connectors are for 3G and 6G video signals that are split over multiple cables due to bandwidth limitations.
Mark Wilson
April 16, 2014 at 3:52 amWill DeckLink 4K Extreme give me two video streams with audio? Also which software will I use to capture the two streams?
Mark -
Chad Pearson
April 17, 2014 at 2:33 amThe Decklink Duo (and Decklink Quad) are the only Blackmagic products that will accept 2 (and 4) SDI inputs simultaneously. To record each signal you need to run the included Media Express software twice by making a copy of the executable binary and giving it a different name (ie. MediaExpress.exe and MediaExpress2.exe on PC). Each Media Express instance will allow you to choose one of the Duo’s (or Quad’s) inputs to begin recording.
