Activity › Forums › Blackmagic Design › HyperDeck Studio Ethernet Connection
  • HyperDeck Studio Ethernet Connection
    Posted by Mandie Clark on July 25, 2013 at 1:36 pm
    It was great to see that 3.8 has an Ethernet protocol for the HyperDeck Studio. I updated software of my Windows 7 Pro machine, and updated the firmware of the HyperDeck unit. I was able to navigate through the menus and setup the IP info. However, the actual Ethernet port itself appears to be inactive – no link lights, and I cannot ping it. Any suggestions?
    Mandie Clark, EIT, CTS
    Communications Electronic Design
    Louisville, KY
    Mandie Clark replied 13 years, 1 month ago 2 Members · 6 Replies
  • Ericbowen
    July 30, 2013 at 8:07 pm
    Are you running through a switch or direct connect?
    Eric-ADK
    Tech Manager
  • Mandie Clark
    July 30, 2013 at 8:30 pm
    A switch. I have 8 units that are doing this (all set to different static IP addresses), and I have talked to tech support who doesn’t seem to be having the same problem with their unit. So I am shipping one back to Blackmagic for evaluation/repair. I have made sure that the static IP set on the unit and my PC have the same domain. I am not successful with pinging the Hyperdeck or telnet (with HyperTerminal) on port 9993 or 23.
    Hyperdeck Studio Firmware 3.8
    Windows Pro 7 SP1 64-bit
    Intel i5 2.40 GHz, 8 Gb RAM, 500 Gb Hard Drive
  • Ericbowen
    July 30, 2013 at 9:00 pm
    Are you able to pull network info from any of the units? How are you setting the IP address for each unit?
    Eric-ADK
    Tech Manager
  • Mandie Clark
    July 31, 2013 at 1:10 pm
    The only way I can get any network info from the units is from the Ethernet menu. That is how I set the Static IP, Subnet Mask and Gateway as well.
  • Ericbowen
    July 31, 2013 at 3:58 pm
    Do you connect via USB at that point?
    Eric-ADK
    Tech Manager
  • Mandie Clark
    July 31, 2013 at 4:05 pm
    No. The only thing I have used USB for is to load new firmware to the Hyperdeck and set the recording format.
