Activity Forums Blackmagic Design Hyperdeck Shuttle used as an HDMI to HDSDI converter?
  • Hyperdeck Shuttle used as an HDMI to HDSDI converter?
    Posted by Bob Pierce on October 30, 2011 at 2:53 pm
    Is this doable? If anyone has experience with this I’d be interested in hearing their experience. Also, if one is using the internal battery, how long can one expect it to work in this capacity? Does it need an SSD to function as a converter? I’d be interested in using it in the field with a DSLR and a pro SDI field monitor.
    Bob Pierce
    Director of Photography • Editor
    http://www.lightstreamassociates.com
    Kristian Lam replied 14 years, 10 months ago 3 Members · 3 Replies
  • Kristian Lam
    November 2, 2011 at 11:04 pm
    Yes, you can use it this way. Just make sure you’re running the latest software update available on our website.
    You should be getting slightly more than 2 hours of runtime when just doing conversion.
    regards
    Kristian Lam
    Blackmagic Design
  • Dave Jenkins
    November 3, 2011 at 6:23 am
    What’s the charging time?
    What is the software you are referring to? Is it a firmware update for the unit?
    Beware of using it with the Panasonic GH2. It adds a buzz to the audio recorded in the camera. I think it’s a problem with the GH2.
    Dajen Productions, Santa Barbara, CA
    MacPro Two 2.8GHz Quad Core – AJA Kona LHe
    FCS 3 OS X 10.6 QT 10
  • Kristian Lam
    November 3, 2011 at 6:44 am
    [Dave Jenkins] “What is the software you are referring to? Is it a firmware update for the unit?
    Yes, that’s correct. You can download it from the Support section of our website.
    regards
    Kristian Lam
    Blackmagic Design
