Activity Forums Blackmagic Design HyperDeck Shuttle does’t playback audio from DNxHD file
  • HyperDeck Shuttle does’t playback audio from DNxHD file
    Posted by Tho Nguyen on August 20, 2012 at 2:26 pm
    Hi all,
    I have copied a DNxHD-Quicktime file, redered by Avid Media Composer 5 (MAC) to the SSD. HyperDeck Shuttle 2 played back the video only (1080i/25), but not the audio (PCM 48 Khz).
    This file can be played back on Mac and Windows PC without problem.
    When record the film via HDMI-Input, the audio is ok.
    Any idea?
    Russell Shaver replied 13 years, 10 months ago 3 Members · 2 Replies
  • Chris Hand
    August 20, 2012 at 3:36 pm
    I am in the same boat, I have tried every different combination of audio settings for DNxHD audio to work correctly and have failed. I have pretty much given up on it until Blackmagic hopefully releases an update or gives specific instructions on how to actually create a DNxHD file that will playback correctly.
  • Russell Shaver
    November 27, 2012 at 9:35 am
    Interested in using the Shuttle as a playback device also. Wondering if you were ever able to get the shuttle to playback audio?
