Activity › Forums › Blackmagic Design › Hyperdeck Shuttle and new SSD (aka OCZ Vertex 4)
Brian Gray replied 13 years, 5 months ago 7 Members · 13 Replies
Jose Lomeña
July 6, 2012 at 8:54 amI can’t believe this. The fastest ssd in the market and is not supported?
I have 2x128gb vertex4 and 2x 256gb vertex4. With firmware 1.4 and 1.5 beta. Can’t record more than 10 second without drops.
I have shuttle 2 and hyperdeck studio. Both with the same drop problem.
When i tested with Blackmagic speed test, the numbers are really high!. Where is the problem?. Will it be fixed in a new update?, or i must search other slower media?
Sebastien Thomas
March 22, 2013 at 1:31 amI just tried the 256G Vertex4 with the Hyperdeck with last firmware and ProRes recording, and I was able to record a one minute clip.
I’ll have more tests soon, but maybe the bandwidth drop when recording ProRes is enough to make this SSD drive working.Nikon D800, D700 – MacbookPro 17″ – Dual 2.66Ghz Macpro – 24″ Samsung screen
Brian Gray
March 28, 2013 at 2:24 amBeen bitten by the same problems
Bought 6 OCZ Vector units for two Hyperdecks
Drives installed in HP workstation for testing – BMD speed test suggest 250 MByte / second write.Sometimes work perfectly in the Hyperdeck ( only ever in slot 2, never in Slot 1 ) recording 1080I25 full res, sometimes, more often, they don’t even register.
A reformat ( Quick ) into exFat ( via Win 7 ) usually cures this but I cannot hand over equipment to my customer like this, and now wasted too much time.
Flashed Firmware in drives to OCX Ver 2 – no difference ( Mar 13 ).
So OCZ Vector Drives do not seem to work in Hyperdecks ( SW V 3.7 )
