Activity Forums Blackmagic Design Hyperdeck Shuttle 2
  • Hyperdeck Shuttle 2
    Posted by Asaf Blasberg on February 1, 2012 at 2:09 am
    Hello,
    Now that it supports DNxHD, is it possible to hook up a 2.5″ hard disk drive instead of a solid state drive like a Western Digital Scorpio? If I’m only capturing compressed HD files? Is it fast enough?
    Asaf
    Levi Nilsson replied 14 years, 6 months ago 3 Members · 2 Replies
  • Dan Nethery
    February 2, 2012 at 5:57 pm
    No, If you plug the HD into the Shuttle or the Studio they will not recognize the drive at all.
  • Levi Nilsson
    February 16, 2012 at 8:32 am
    Keep in mind that the shuttle is also running on battery power and the requirements of a spinning platter drive are MUCH higher than an SSD. The power of this system is its size, durability, battery life, and now, flexible file structure. Using a spinning drive would lessen the run time, destroy the durability factor and generally compromise the design. And for the price, these are still a smokin tool!
