Activity › Forums › Blackmagic Design › HyperDeck as instant replay?
Posted by Liudas Vasaris on February 27, 2012 at 1:25 pmIs it possible??
Jared Ganem replied 14 years, 1 month ago 4 Members · 7 Replies -
Richard Crowley
February 27, 2012 at 6:23 pmDepending on exactly what you mean by “instant”, it is quite possible. Note that longer recording files take longer to “close”. So “instant” may mean “several seconds” before you can go and play something back.
And note also that it isn’t necessarily easy to find the exact spot in a hurry, even if you wrote down the timecode of the spot you want to see.
Liudas Vasaris
February 27, 2012 at 8:36 pmOf course it should have much “inconvenience”, but it’s interesting how it would look in the field…
So it’s possible to add JLCooper MCS2 Media Control Station to HyperDeck Studio via RS422 and have “poor mans” replay system?:)
But does it have option for slow replay, I just found in manual about fas forward, but nothing about slow motion.
Paul Lewis
February 28, 2012 at 10:45 amWe tried a Hyperdeck Studio that was loaned to us, in our truck.
Using a DNF 300 slo-mo controller, it worked okay except for a couple of quirks. When recording, the DNF stop button doesn’t stop it, you have to use the Hyperdeck’s stop button, also there was frame interlace jitter when paused, doing 601 NTSC [SD-SDI]. Now this is with the factory firmware, and recording in uncompressed 10bit QuickTime. Also you need a Mac with a SATA drive dock, to format and erase the SSD.
Things may change with firmware updates.Cheers,
Paul Lewis -
Liudas Vasaris
February 28, 2012 at 1:58 pmThanks Paul,
but does Hyperdeck Studio have option to play recorded clip in 70%? Can you confirm this, becouse I dont find any information about this.
Paul Lewis
February 29, 2012 at 3:13 amI will talk to the Replay Operator that ran it in our truck, it was loaned to us by another company, so I don’t have it anymore.
Cheers,
Paul Lewis -
Paul Lewis
February 29, 2012 at 3:41 amJust chatted with Chris, who ran the BMD Hyperdeck studio on our truck for a basketball game,
He said it seemed to run at whatever playback rate the DNF slow motion controller called for,
so you could start from a dead still frame and ramp it up to full playback speed,
I know on the built in control panel there is a way to make a clip loop,
but I don’t know if you can get it to run a clip at a variable rate, except by using a external controller. so 70%? maybe!
if you have a rs-422 controller that does variable playback.
Maybe in future firmware upgrades it will learn more tricks!Cheers,
Paul Lewis -
Jared Ganem
August 13, 2012 at 4:12 pmHey, I know it’s an older topic but has anyone had any success with this using JLCooper Media Control? I’m curious to see if it’s worked and also how you think it’d work with the upcoming release of Hyperdeck Studio Pro. Thanks!
