Activity › Forums › DVD Authoring › Hybrid/Combo DVD/CD???
Posted by Vic on August 4, 2005 at 9:01 pmI’ve got a client looking to create a DVD that will also play normal audio if inserted in a CD player.
How can i do this?
Chris Borjis replied 21 years, 1 month ago 6 Members · 6 Replies -
Robert Wilson
August 5, 2005 at 12:25 amThis isn’t going to happen. CD players just simply cannot read DVDs. They may look similar but they are definitely not the same.
Arnie Schlissel
August 5, 2005 at 12:36 amI’ve heard of these. Don’t expect to find blanks at Wall-Mart or CompUSA. These disks are custom made to order by replicator houses. You have to give the replicator separate masters for the DVD & the CD sides. You’ll have to order at least one or two thousand, though.
Arnie
https://www.arniepix.com -
Bill Stephan
August 5, 2005 at 3:38 pmIt’s almost impossible to adhere a CD and a DVD layer without making the resulting disc over-spec for thickness, so these discs might be problematic in some players.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City -
Chris Borjis
August 5, 2005 at 4:01 pmIf your content is not very long (less than 10 minutes) you
might be able to do a Hybrid CD-Extra/CDVD.that is…a cd with redbook cd audio on one part and a rom
section with the VIDEO_TS dvd content on it.I’ve made them before, they only play on computers but the
cd audio would play in any cd player. -
Dither
August 5, 2005 at 5:26 pmThere is such thing called Dual Disc which is basically a CD on one side and a DVD on the other. https://www.dualdisc.com
Dither
https://www.hellmanproduction.com
