Activity Forums Panasonic Cameras HVX200a lens recommendations
  • HVX200a lens recommendations
    Posted by Lawrence Richards on May 2, 2013 at 8:33 pm
    Hi All,
    Rather than sell my HVX200 for something else just so I can achieve a better dof and image control, I’m opting to upgrade the stock lens the camera comes with. My questions are this:
    1. What are the choices of adapters I should look into?
    2. What prime lenses should I look into?
    Thank you!
    Thank you!
    Larry R.
    Florida
    Lawrence Richards replied 13 years, 4 months ago 2 Members · 4 Replies
  • Matthew Sonnenfeld
    May 6, 2013 at 7:21 pm
    The HVX200 has a fixed lens that is built as part of the camera as a whole. It cannot be replaced. Your only option for this would be a 35mm adapter such as the Letus35 or the Redrock Micro M3.
    Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    AJA IoXT
    Adobe Production Premium CS6, Avid Symphony 6, Final Cut Pro Studio 3
    The College of William and Mary
  • Lawrence Richards
    May 6, 2013 at 7:30 pm
    Hey Matthew,
    Ok, great. And from there I would just buy a 35mm lens and I’m good to go?
    Thank you!
    Larry R.
    Florida
    May 6, 2013 at 10:37 pm
    That would be the idea. Get the adapter in your mount of choice and get the lens you want. But keep in mind that you will have 35mm depth of field but you will also lose typically half a stop of light. Not a huge deal most of the time but on the HVX in a low light situation, it may be. It will also mean extra weight and more pieces which means more that can go wrong. The AF100a or the Sony FS700 are both options that at the cost and drawbacks of the adapters might be worth looking into. But if you want an adapter, the Letus35 Ultimate is pretty much the best there is and costs on it have come WAY down from where they were.
    https://www.letus35.com/store/Letus-Ultimate-Depth-of-Field-Adapter.html
    AJA IoXT
  • Lawrence Richards
    May 10, 2013 at 7:25 pm
    Thank you!
    Thank you!
    Larry R.
    Florida
