Activity Forums Panasonic Cameras HVX200 zoom problems
  • HVX200 zoom problems
    Posted by Tj Nelson on August 20, 2009 at 4:37 pm
    Seems some gremlins have made their way into my camera or someone was dinking with my settings and I don’t know how to revert them.
    1) My handle zoom doesn’t work. I’ve gone through the menus and changed them from L/M/H to L/off/M to L/off/H and none of those functions at pos. 1, 2, or 3 control the zoom. (Yes I made sure the zoom switch was set to Servo)
    2) When switching the zoom to Servo, the rocker next to the palm grip works (sorta). Zooming in works fine and zooming out works fine, but when in the neutral position it zooms out on it’s own.
    That being said, I assume that I need to take it in to a Panasonic authorized shop but I was wondering if there are any ways around it. ..tough economic times and all 🙂 .
    Thanks for any light shed on my dim little subject.
    Eric Ranzenhofer replied 17 years ago 4 Members · 4 Replies
  • Noah Kadner
    August 20, 2009 at 4:52 pm
    That’s internal electronics, needs to be professionally repaired.
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
    Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
    https://www.callboxlive.com
  • Tj Nelson
    August 20, 2009 at 4:56 pm
    Figured as much. Thanks.
  • David Perry
    August 22, 2009 at 2:33 pm
    I have had similar issues with the uncontrolled zooming out. By any chance do you have a Varizoom lanc controller hooked up the zoom/focus remote inputs. That has been a problem for me and possibly it has something that the remote is overriding in your menu controls. Is there a menu setting to turn off the remote control of the camera?
    Just a guess.
    David Perry
    David Perry
    Carmen Productions
    Leesburg, VA
  • Eric Ranzenhofer
    August 27, 2009 at 9:52 pm
    I had the same problem on 2 cameras last week.sent to pana dealer(inter cité video here in montreal) and they fixed it.I use a vari zoom but I dont think that it is not the problem but i will loock in to it because they changed some parts $80,00 +shop time 2hrs
    part:
    vgu0d01 top opp button
    vw06h2033lo flex
    vw12h2120l0 flex
    vmz3465 cushion
    vmt1749 sheet
    good luck
