Activity › Forums › Panasonic Cameras › HVX200 vs. HDX400
  • HVX200 vs. HDX400
    Posted by Jack Gordon on October 8, 2005 at 3:43 pm
    https://panasonic-broadcast.com/index.cfm?uuid=A130E452C09F11269B89B84D8643F16D&pid=11461&catid=4285&ClassID=77
    You can download a brochure by clicking “download leaflet”. Don’t try to download the catalog; if you do, you will not be able to download even the leaflet.
    How do the two cameras compare in image quality? HDX400 has 1080/25 mode in Europe, with 700 lines horizontal resolution, 2/3″ progressive chips chips running at 50 Hz, 6.7:1 compression, min. 1/60 sec. shutter, F10 low light sensitivity, HD-SDI output, 54 dB S/N camera section, 12 bit prosessing.
    I realize that the larger camera will be better, but by how much? I think that the resolution will probably be similar, or about equal to Varicam’s.
    Jack Gordon replied 20 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
