Activity Forums Panasonic Cameras HVX200 Timelapse and Stopmotion?
  • HVX200 Timelapse and Stopmotion?
    Posted by Jon Slagle on May 31, 2007 at 8:40 pm
    I am trying to figure out some of the timelapse settings for my new HVX200, but I’m not sure where to look an/or find where the settings are and how to access and adjust them.
    Bill Paris replied 19 years, 3 months ago 3 Members · 4 Replies
  • Bill Paris
    May 31, 2007 at 9:47 pm
    Make sure the camera is in the P2 mode…..push the “menu” button on top of the camera….go to option #5 “Recording setup”……Select “Recording Format” and choose 720p/60…….make sure the wheel on the back of the camera is set to F1, F2 or F3……on the same menu page go down two clicks and select “Rec. Function” when you select it, choose “Interval”….then go down two clicks to “Interval Time” and select the number of frames you want to record per second…minute…etc. A good starting point is 1 frame per second. Now everything is selected……push the menu button a couple of times to get rid of it…..now you’ll see a green flashing “I-Pause” at the top of the screen. The camera is ready to record timelapse…..push the record button and your off! To get out of the pause mode, switch the camera off for a moment and go into playback mode to check your recording.
    Good Luck!
    Bill Paris
    Director of Photography
    Crew Hawaii Television
  • Rmherd
    June 5, 2007 at 7:08 pm
    to stop the intervalometer, push the stop button on the top of the camera.
    RH
  • Rmherd
    point to clarify, not the red button the VCR-type stop button.
    RH
  • Bill Paris
    June 7, 2007 at 8:28 am
    Sorry it’s taken me a while to get back to you…..as I’m sure you figured out, you actually turn the camera off for a moment to get out of the interval record mode.
