Activity › Forums › Apple Final Cut Pro Legacy › hvx200 sp mode 24p
hvx200 sp mode 24p
Posted by Roberto Pierson on September 28, 2010 at 12:01 amhi, i shoot footage on the hvx200 sp 24p mode on to tape but im having problems with final cut because the footage is not showing as 23.97 but is showing at 29.97 even tough its being imported at 23.97, any suggestions on the workflow?
thanksCharles House replied 13 years, 9 months ago 4 Members · 6 Replies -
Shane Ross
September 28, 2010 at 12:06 am[roberto pierson] “i shoot footage on the hvx200 sp 24p mode on to tape but im having problems with final cut because the footage is not showing as 23.97 but is showing at 29.97”
Correct. The tape records DV at 29.97. It does not record at 23.98fps. 24p is just a 24fps look recorded on tape at 29.97.
[roberto pierson] “any suggestions on the workflow?”
Capture and edit 29.97.
Shane
Read my blog, Little Frog in High Def -
Roberto Pierson
September 28, 2010 at 12:30 amthank you, so does that mean i have to run it trough compressor to make it 24p? if so what codec should i use.
thanks -
Shane Ross
September 28, 2010 at 12:42 amIt is 24p. It just isn’t 23.98. Why do you need it to be 23.98? What is your intended final output going to be?
Shane
Roberto Pierson
September 28, 2010 at 1:41 amits intended for distribution, the reason i asked these questions is because i recently shot a documentary using a canon hv40, i shot at 24p but the actual footage was not 24p , but 24p interlaced with 60i so i had to run it trough compressor to de interlace it and make it true 24p, so my question is just leave it as is and import and cut at 29.97 or will this be a problem with the footage being interlaced? or should i just run it trough compressor and make it true 24?
thank you -
Michael Sacci
September 28, 2010 at 2:39 amIn Compressor you turn on Frame Control and set deinterlace to Reverse Telecine, But if your other footage is 29.97 you may just want to stick with 29.97 or do the Reverse Telecine on that footage also.
WIth the HVX in SD if you want true 24p (23.98) you need to shoot it on 24pA and then remove the advanced pulldown on capture.
If you are going out to the web or to DVD this is what you want to do.
Charles House
November 30, 2012 at 12:57 amDave, I have to ask… Why do you always have to make things more complicated for people struggling to grasp a concept, much less be patronizing and belittling about it?
