Activity › Forums › Panasonic Cameras › HVX200 – Shoot Aurora Borealis?
Posted by Eric Steinberg on December 6, 2005 at 1:38 pmHello!
Does anyone know if the HVX200 will be capable of capturing Aurora Borealis (the northern lights)? In still-photography an average setting on the camera would be appx.
aperture f2.8
exposure time 10 -15 sec.
film speed 400 ISO.Kind regards,
EricEric Steinberg replied 20 years, 9 months ago 5 Members · 11 Replies -
Blub06
December 6, 2005 at 4:54 pmI think Sony owns to North American rights to the Aurora, so you better watch out you better not cry.
Chris
Noah Kadner
December 6, 2005 at 5:49 pmDon’t see why not… With all those frame rates I’m sure one of them would do it.
Noah
Toke
December 7, 2005 at 6:46 amSo it really will be possible to record exposures like 10 seconds per frame with hvx?
Noah Kadner
December 7, 2005 at 7:10 amNo I didn’t say that… Just that you’d probably be able to get a usable shot but not like still photography.
Eric Steinberg
December 7, 2005 at 8:06 amI don’t know, but I’m guessing the light sensitivity of the ccd’s would be a factor..? Don’t know how to calculate what specs the HVX200 would have to have to accomplish this, maybe someone has a formula?
Kind regards,
Eric -
Ksmith
December 7, 2005 at 5:10 pmWhy not just shoot stills in time lapse and then bring them into a NLE (preferrable a NLE that excepts HD!) and then edit them into a sequence.
Noah Kadner
December 7, 2005 at 8:24 pmFrom the new FAQ:
Does the HVX200 record still images?
The HVX200 can do a single frame capture in the intervalometer section of the camera. If you use an NLE application, you will be able to select that frame on the timeline and export it as a single still frame. -
Eric Steinberg
December 8, 2005 at 9:03 amLooks like in the press release that the still images the HVX200 can take, the max exposure time is 1 second. My question then is: Is the light sensitivity good enough to capture the low Aurora borealis light? Like I mentioned in my first post, on a regular still camera, I need to keep the shutter wide open for 10 – 15 seconds to get acceptable exposure. Will 1 second on the HVX200 work?
Kind regards,
Eric -
Toke
December 8, 2005 at 6:16 pmFor example lets compare the pixel area of Canon D5 and HVX200:
D5: 67
