Activity Forums Panasonic Cameras HVX200 P2 Question
  • HVX200 P2 Question
    Posted by Scott Gray on October 5, 2006 at 7:14 pm
    Shooting on an HVX200, using the P2 cards. Every clip that I import into FCP ends up at 29.97 no matter what progressive frame rate that I shoot in. Is there something in FCP that I need to do before I import?
    Mike Schrengohst replied 19 years, 11 months ago 4 Members · 4 Replies
  • Shane Ross
    October 5, 2006 at 8:24 pm
    YOu need to set the camera to 24PN in order for it to record 24 true frames per second. If you shot 30p, then they’d come in at 29.97.
    When you import, FCP does not change the frame rate of the clips. That is all determined by the camera…so when you import it and it says 29.97, then it was shot 29.97. Double check your settings.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Izoneguy
    October 5, 2006 at 8:45 pm
    Hello Scott:
    If you shot 24p not 24pN it will show as 29.97
    you can use Cinema Tools and reverse tele-cine to
    get a 24p file you can use in a 24p timeline…
    Mike Schrengohst
    dvd.pro@verizon.net
  • Shane Ross
    October 5, 2006 at 8:49 pm
    Uh…no it won’t. It will show up 23.98 if it was shot 24PN on a P2 card.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mike Schrengohst
    October 6, 2006 at 3:04 am
    Thats what I said…
    If Scott shot 720 24p NOT 24pN then it would show up as 29.97….
    I have the largest stock footage collection of 720 23.976 and 1080 23.976
    footage around…this month the collection will be increased dramatically
    and some special surprises for November should propel it along quite nicely!!
