Activity Forums Panasonic Cameras HVX200 P2 Problems with de-interlaced frames.
  • HVX200 P2 Problems with de-interlaced frames.
    Posted by Cornelius Henke on September 2, 2008 at 4:33 pm
    System:
    OSX 10.4.11
    FCP 6.0
    QT 7.5
    I have been reading other peoples complaints with importing P2 footage and I have fallen into a similar situation, but mine seems to be far more different than the rest.
    I shot 1080i24PA on an HVX200 (Almost positive, but am now doubtful about it just being 1080 24).
    I have setup FCP in multiple ways before posting on here and I continue to get a variation of the same problem.
    I am getting deinterlaced frames which I believe are from a pull down that finalcut pro is not recognizing.
    But I tested as follows and still not the results I desire.
    Setup project with 1080i24pA, with frame rate at 23.98.
    Imported footage. Results, deinterlaced.
    Setup project with 1080i24pA with all frame rates.
    Same as above
    With both of those settings I logged and transferred footage with and without the remove pull down in the preferences sprocket.
    With both of those settings I changed my sequences settings to: DVCPRO HD 1080p30, & DVCPRO HD 1080i60
    Here are some stills of the results:
    https://www.smallsmoney.com/myspace/test/Picture25.png
    https://www.smallsmoney.com/myspace/test/Picture26.png
    I need help.
    CJ
    Cornelius Henke replied 18 years ago 2 Members · 5 Replies
  • Richard Herd
    September 2, 2008 at 6:31 pm
    The footage is what it is, and in my experience FCP is very good about reporting the metadata facts.
    Make a new setting that corresponds to those facts; rather than creating the sequence something the footage isn’t. (Sorry if that’s awkward.)
    Please include a screen capture of your footage bin.
    Additionally, deinterlaced video differs from progressive video, and it’s a weird topic. There’s a great explanation at https://www.lurkertech.com
  • Cornelius Henke
    September 2, 2008 at 9:16 pm
    Rich,
    Thanks for the fast response. Is there a way to read the metadata without the camera? I only have my computer and the card data files.
    Here is the bin file information. I see that it is using the compressor 1080p30, but how can I change that. My resulting footage has 3 frames that are de-interlaced, followed by 2 good frames, then 3 de-interlaced, then 2 good. would that be 2:3:2:3?
    Thank you for helping me to understand.
    New Bin Photo:
    http://www.smallsmoney.com/myspace/test/Picture27.png
  • Cornelius Henke
    September 2, 2008 at 11:06 pm
    Rich,
    I justed used P2 Log Pro to identify the metadata and it said that I shot 1080i60 30fps, but I have changed the project to work with that specific data and I am still receiving the problems with de-interlacing even when I click the remove pulldown.
  • Richard Herd
    September 3, 2008 at 5:08 pm
    There’s two parts. First part is how to fix it. Second part is what I believe is going wrong.
    1. You’ll have to use Apple Compressor to transcode your footage into the SAME format. That is, the frame size, Vid Rate, Compressor, Aud Rate will all need to be the same. Since most of your footage is DVCPRO HD 1080p30 @ 23.98 fps, then I suggest transcoding the 29.97 fps footage into that vid rate, simply because it appears it will take less time. Make sure your sequence corresponds to this new “stuff” (frame size, vid rate, etc.)
    2. I believe that the error you’re seeing is caused by placing mismatched footage into a sequence. I assume that also means you’re having to render in the sequence. A good rule of thumb is if you bring footage into a sequence and you have to render, something is wrong, so stop and figure it out. FCP Studio 2 is cool because it will “auto pick” your sequence presets. (Why they didn’t do this with 4.0–when I started FCP–I’ll never know!) But that won’t solve your problem because your vid rates differ.
    Vid Rate is a trippy thing. Imagine the first frame as being 0, followed by the second frame 1, then 2, 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 then where does it go? Well, if you’re in a 23.98 sequence, then it goes to the next second, but if you’re in a 29.97 sequence, then it goes to 24 25 26 27 28 29, but since the footage itself is 23.98 and the sequence is 29.97 (or vice versa), then the computer has to recount the old frames. But it doesn’t “transcode” the vid rate. Instead, it creates a render file which tells the sequence what the new vid rate is. It’s terribly complicated.
    2:3:3:2 is way different. It’s about video FIELDS not frames, lots more on that but I’ll skip it. Anyway, when we edit in FCP we do not make our edits on fields, but on frames, so the fancy math creates a frame out of fields. But the two fields exactly next to each other will not match up, so the fields must be interleaved to create a frame. If you assume it takes two fields to make one frame, then you’ll notices 2:3:3:2 means something like “the first frame has two fields, the second frame has three fields, the third frame has three fields, the fourth frame as two fields.” Add the number of fields up 2+3+3+2=10. That means 10 fields are making 4 frames. Normally, we’d expect 2 fields to make 1 frame, so 10 fields should make 5 frames. But that extra frame has been “pulled down.” Here’s a bit of video blasphemy: this “pull down” all by itself won’t make your video look like film 🙂
    Well, that’s my best guess on what’s going wrong, and I hope someone checks this post for accuracy!
  • Cornelius Henke
    September 3, 2008 at 6:29 pm
    I have it figured out to a point that I can work with now. I did not have to render any of the footage that I placed into my timeline, but through a cinematools reverse telecine converting from 29fps to 24fps, it has fixed my problem. I no longer see the de-interlaced frames. The frame rate itself is a little off, but ends up just looking like a high shutter speed from in camera. I agree that compressor would be another way of doing this in a similar fashion.
    Thanks for all the help…
