Activity Forums Panasonic Cameras Hvx200 Frame rate problem.
  • Hvx200 Frame rate problem.
    Posted by Stuart Mcintyre on December 20, 2010 at 3:00 pm
    Bought another second hand HVX200 for Documentary use. The most recent camera that i got goes to 50fps each time i turn it off and i have to go through the menu to reset it. I’m sure you understand that this is not ideal when its use is for documentary. This is probably just a stupid mistake that i am making. But i would really appreciate if someone could point out what the problem is
    Many thanks!
    Stuart.
    Frank Nolan replied 15 years, 8 months ago 2 Members · 1 Reply
  • Frank Nolan
    December 23, 2010 at 12:19 am
    Are you saving the setting, before you turn it off, when you reset it?
