Activity › Forums › Apple Final Cut Pro Legacy › HVX200 footage from FCP to DVD?
Posted by Billyhd on June 26, 2007 at 5:58 pmhi there,
i shot some footage using the HVX200, and edited it using final cut pro 5. my sequence settings are HD (960×720) (16:9) (i.e., letterboxed).
i am now trying to burn a high-quality DVD of this movie, intended for viewing in North America. could anyone please tell me what settings to use to (1) export the movie from FCP and (2) burn a DVD in DVD Studio Pro? i want the quality to be as high as possible.
many thanks!
Billyhd replied 19 years, 3 months ago 3 Members · 7 Replies -
Shane Ross
June 26, 2007 at 6:05 pmExport from FCP a QUICKTIME MOVIE. Self contained or not…doesn’t matter. Sequence settings…yes.
Open Compressor. Drag the exported movie into Compressor. CHoose HIGH QUALITY then the time appropriate for you video, like 90MIN, 60MIN…what have you. This is a 2pass VBR. AIFF, DOLBY…up to you. I use DOlby. Then hit submit.
Import the result into DVD Studio Pro and author the DVD.
Shane
Littlefrog Post
http://www.lfhd.net -
Billyhd
June 26, 2007 at 6:43 pmshane,
thanks very much for your response. could you please be a bit more specific, though? what settings should i use when exporting my project as a quicktime movie (compression type, compression quality, encoding, data rate, optimization, etc.)?
thanks!
Steve Eisen
June 26, 2007 at 6:51 pmShane told you as specific as he could. When you export as QuickTime Movie, you will keep your sequence settings.
It is up to you to decide your compression rate in Compressor based on the length of your video.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Shane Ross
June 26, 2007 at 6:51 pm[billyhd] “what settings should i use when exporting my project as a quicktime movie (compression type, compression quality, encoding, data rate, optimization, etc.)?”
None of that. You are NOT to export as a QuickTime CONVERSION…no no. QUICKTIME MOVIE…the first option. Then you just make sure that you are using the sequence settings, and either make it self contained, or leave that unchecked which makes a reference movie (a smaller files that points to the original media on the Scratch drive) and use that. There are no compression type, quality, encoding crap in that option. And if you do Quicktime Conversion…you are adding compression so AVOID THAT.
Compressor is where the real compression happens.
Shane
Littlefrog Post
Billyhd
June 26, 2007 at 7:53 pmshane and steve,
thanks very much for your help.
everything you’ve said makes sense so far. i just need to know how to open compressor…
(sorry if this is an elementary question … this is like my first time using FCP).
Shane Ross
June 26, 2007 at 7:56 pm[billyhd] “i just need to know how to open compressor…”
Double Click on it. It is in the Applications folder.
Time to crack open the manual and look there for the step-by-step.
Shane
Littlefrog Post
http://www.lfhd.net
