Activity › Forums › Panasonic Cameras › HVX200 Film Back or Back Plate dimensions
  • HVX200 Film Back or Back Plate dimensions
    Posted by Jeff Petersen on January 15, 2007 at 7:45 pm
    I’m using 3D tracking software on my HVX200 footage and have no idea what the Back Plate dimensions (called in Syntheyes) or Film Back dimensions (called in Bojou) is/are. Part of making a good track is being able to find this info out. Anybody have any idea and or experience tracking this footage?
    thanks,
    Jeff Petersen
    Uli Plank replied 19 years, 8 months ago 2 Members · 4 Replies
  • Uli Plank
    January 16, 2007 at 6:10 am
    We got good results in Boujou without this info, but it should be 1/3″ diagonally, like all the rest in this class. More exact dimensions might be hard to find in a manual, but you can use Phytagoras and the fact that it’s 16:9 to find out…
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
  • Jeff Petersen
    January 16, 2007 at 6:33 am
    thanks Uli,
    so it is referring to the size of the Chip? i didn’t even know what it was referring to.
    Since you said you got good tracking on your HVX footage can i ask you your camera settings in the Boujou camera dialogue? My footage always imports looking “Squished”. Not proper aspect somehow, but i don’t know how to change it.
    The default camera settings that boujou opens for me when i import a 720p clip is/are:
    Film Back- Width .79213 and Height .59349 (Units: inches)
    Resolution: 985×738 (This is not changeable in this window. it seems like this would fix my problem but i can’t find where to adjust it).
    Ratio: 1.3347 (also can’t find where to adjust)
    Pixel Aspect: 1
    Frame Rate: 24
    Lens Squeeze ratio: 1
    any help would be much appreciated.
    thanks,
    jeff
  • Jeff Petersen
    January 16, 2007 at 6:34 am
    thanks Uli,
    Pixel Aspect: 1
    Frame Rate: 24
    thanks,
    jeff
  • Uli Plank
    January 16, 2007 at 8:30 am
    I’m first converting my image sequences to true 1280 x 720
