Activity Forums Panasonic Cameras HVX200 captured direct to FCP on laptop?
  • HVX200 captured direct to FCP on laptop?
    Posted by Robert Depalma on March 28, 2007 at 6:09 pm
    Does anyone know if it’s ok to capture 720_30P from an HVX200 via firewire to a laptop with Final Cut Pro 5.1.2? I’ve tried it and it seems to work. I just don’t know if the two are designed to work together in this setup.
    Also, one issue I found is with the timecode. Since the only way I can get FCP to capture is by putting it on “non-controllable device”, Ithe timecode keeps going back to 00:00:00 for every clip. Any solution for that? I tried searching for a setup suggestion for this, but couldn’t find anything.
    Thanks in advance for any help!
    Robert Depalma replied 19 years, 5 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    March 28, 2007 at 8:21 pm
    [Robert] “Does anyone know if it’s ok to capture 720_30P from an HVX200 via firewire to a laptop with Final Cut Pro 5.1.2?”
    Yep, it works. A DP buddy o fmine operates like that ALL the time.
    [Robert] “ince the only way I can get FCP to capture is by putting it on “non-controllable device”, Ithe timecode keeps going back to 00:00:00 for every clip. Any solution for that?”
    Nope, them’s the FCP brakes. It won’t read tc if it’s set to non controllable.
    Jeremy
  • Robert Depalma
    March 29, 2007 at 12:31 pm
    thanks for the reply! I guess it’ll work for non-mobile setups.
    Looks like a Firestore is in my future for the rest.
