Activity Forums Adobe Premiere Pro HVX200 and Premier Pro
  • HVX200 and Premier Pro
    Posted by Mark Weaver on May 21, 2007 at 10:01 pm
    Hello,
    I know this question must have been asked a hundred times,
    but I can’t seem to find a good answer. I am considering buying
    a HVX200 and wonder what the workflow with Premiere Pro is.
    The main use would be indie filmaking.
    So… Cinefore? Some software from MainConcept? Native?
    Any ideas/experiences or suggestions would be very helpful.
    MBW
    Mark Weaver replied 19 years, 3 months ago 2 Members · 6 Replies
  • Marcus Van bavel
    May 21, 2007 at 10:59 pm
    Suggest you look at Raylight, see https://dvfilm.com/raylight
  • Mark Weaver
    May 22, 2007 at 12:43 am
    Marcus,
    Thanks for the link. So do you use Raylight? What about
    the Cineform with Raylight decoder? What are your experiences?
    Mark
  • Marcus Van bavel
    May 22, 2007 at 1:59 am
    I’m the author of Raylight.
    Interestingly, you can bump back and forth between the Raylight decoder and the Panasonic decoder by switching back and forth between Raylight Blue and Raylight Green (Raylight Green in the new release of Raylight uses the Panasonic decoder to do fast previews). The extra noise in the Panasonic decoder is very apparent in, for example, dark areas with horizontal lines. For that reason you should only use it for a preview, never a final render of your program.
  • Mark Weaver
    May 22, 2007 at 2:40 am
    The author… Wow… Thanks for taking the time to help me out.
    So if I understand correct, when using the Raylight decoder,
    there is less articfacting than the Panasonic viewer decoder. I
    must have missed the link on workflow for Raylight. Need to go
    back an check it out again. So, how does this all work with the
    CineForm AspectHD. I see mention of it on your sight, but I’m
    not clear. The Cineform site seems to indicate that there
    intermidiate format is great… Hmmm.. I think there is more to
    learn…
    Thanks again!
    MBW
  • Marcus Van bavel
    May 22, 2007 at 5:37 am
    What might be confusing is that there are two separate products:
    The Raylight system allows you to bring MXF files directly into Premiere (or Vegas) and edit native DVCPROHD. Premiere+Raylight is all you need to edit with the HVX200.
    The other product is Raylight Decoder, which is a set of decoder plugins for CineForm and Quicktime. It replaces the Panasonic decoder in CineForm HDLink and improves its image quality. The link for the decoder is here: https://dvfilm.com.raylight/decoder
  • Mark Weaver
    May 22, 2007 at 3:17 pm
    Marcus,
    Ah ha…. Now I get it. The raylight decoder is used
    with CineForm, but that flow allows conversion to CineForm
    intermediate, where as just using the Raylight interface
    allows editing directly the MXF files. Okay so no matter
    what, the actual P2 card files need to go through some
    sort of conversion before being usable in PPro.
    Thanks for the help Marcus!!!
    MBW
