Activity Forums Panasonic Cameras HVX Timecode after Dropping Frames on Import
  • HVX Timecode after Dropping Frames on Import
    Posted by Urban Rhino on July 13, 2006 at 2:14 am
    The HVX Records most 720p formats in 60P and then you drop tagged frames on import which gives you the actual frame rate you shot at, correct? Now what you’re left with is a clip that goes 1:00:23:00 to the next frame being 1:00:23:03. Seems like a potential EDL nightmare. Is there a simple way to make the new time code linear without having to go in modify the timecode of each clip individually?
    Urban Rhino replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
