Activity Forums Panasonic Cameras HVX Sensitivity
  • HVX Sensitivity
    Posted by Drew Harty on March 27, 2006 at 1:48 am
    Hello,
    Does anyone know what the sensitivity of the HVX is? And is that sensitivity for DV, HD progressive or interlaced or are they all the same? I am trying to get a fix on what the exposure factor will be going from a 60i SD camera with a F/11 @ 2000 Lux standard sensitivity to the HVX shooting 720 30p.
    Also, can you transfer footage directly from a P2 Store to a stand alone hard drive?
    Drew Harty
    Steve Freebairn replied 20 years, 6 months ago 3 Members · 2 Replies
  • Häakon
    March 27, 2006 at 10:46 am
    Depends on who you ask.
    I’ve heard the equivalent of 320 ASA being thrown around by a couple people, but that’s just a number. In my tests, it has performed 1 1/2 – 2 stops slower than my DVX100A. Best thing to do is test it yourself in a controlled environment and see if it meets your needs. Good luck to you.
  • Steve Freebairn
    March 27, 2006 at 2:23 pm
    One reason why the HVX200 is not as sensitive, is because of the nature of Progressive ccd’s vs. interlaced ccds. I’ve read articles (like this one) https://www.showreel.org/memberarea/article.php?172 that suggest an ISO of 320, but I’ve also read alot of people talk about how the HVX needs a lot more light. One thing is for sure, if you do need to boost your gain in post, it will still look better to downrez a hd signal that has been boosted rather than use SD.
