Activity Forums Apple Final Cut Pro Legacy HVX P2 project needs work
  • HVX P2 project needs work
    Posted by Tyler Dixon on June 4, 2008 at 10:55 pm
    I have to re-color an older P2 project that was shot an edited last year. Back then, we had to do it in another FCP room we have that still used QT 7.2.
    I just tried using an original clip on a newer FCP room with the latest 7.4.5 (25) and FCS2 6.0.3 and it will not recognize the files. ARe there still problems with P2 and the latest QT 7.4.5 (25)?
    Jeremy Garchow replied 18 years, 3 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    June 5, 2008 at 3:03 am
    [Tyler Dixon] ” ARe there still problems with P2 and the latest QT 7.4.5 (25)?”
    Not that I have seen, no.
    What do you mean it won’t recognize the files?
  • Gary Gowman
    June 5, 2008 at 3:42 am
    I have LTO tapes from the original project that were then put on G Raids for re edit/cc. None of the clips work. I get the messaged unrecognized blah blah. The guys that worked here on it befor said they stayed in QT 7.2 to work only on this P2 project because there were issues with P2 and QT. I believe it was an HVX 200 shoot.
    The files have no extension (mov) in the the filenames. Yet they open still on the old QT 7.2 computer. I did open some on that computer and resaved with QT (7.2) and those work on all of our updated FCS stations. But I can’t resave all the clips for original sources for a 90 minute movie. 🙁
    BTW, I posted earlier on Tyler’s computer.
    Gary Gowman-Video Director
    Louisiana Media Services
    4K, 2K/DI, HDcamSR
    Assimilate Scratch and FCS2/Kona3 Suites
    Full Audio Production
  • Jeremy Garchow
    June 5, 2008 at 4:20 am
    Cool. Thanks for letting me know Gary not Tyler.
    Do you have access to the original CONTENTS folders or just the QT movies?
  • Gary Gowman
    June 5, 2008 at 5:16 pm
    Hi Jeremy,
    We just recovered some files from an LTO tape that appears to have the final project file (.fcp) and relinked the original source media. But it still has to be re colored and edited on the older QT 7.2 system because of what I have described. At least I can now finish what needs to be done.
    But I still do not understand why it has to be. I am guessing because they imported all the HVX footage on that older QT version and the newer versions of QT are not backward compatible. In other words, I could reimport “all” the original files again, but that is too time consuming.
    Best regards,
    4K, 2K/DI, HDcamSR
  • Jeremy Garchow
    June 6, 2008 at 4:07 am
    [Gary Gowman] “At least I can now finish what needs to be done. “
    Fair enough.
    [Gary Gowman] “But I still do not understand why it has to be. I am guessing because they imported all the HVX footage on that older QT version and the newer versions of QT are not backward compatible.”
    COuld be, P2 support has gotten incrementally better since ‘way back then’.
    [Gary Gowman] “n other words, I could reimport “all” the original files again, but that is too time consuming. “
    It doesn’t take that long, way faster than tape capture. As long as the p2 data is loaded in the log and transfer window, simply select a p2 clip in the browser, right click and choose batch capture and FCP will do the rest. It’s much faster to make sure that FCP is tracking the data right now, than it is to do later.
    Jeremy
