Activity Forums Panasonic Cameras HVX P2 FCP 5.4.1
  • HVX P2 FCP 5.4.1
    Posted by Fm12345 on April 15, 2007 at 12:38 am
    One or two clips imported into FCP from P2 Store play at double speed (13.99 fps), yet audio is fine, only video is fast. Halving the speed in FCP doesn’t solve the problem. What happened?
    Jon Chen replied 19 years, 4 months ago 3 Members · 2 Replies
  • D. scott Dobbie
    April 15, 2007 at 4:45 am
    How does it look prior to import? Does it display correctly? If so, your sequence settings for FCP might not be matching – they need to be the same as what you shot. If you’re using the same sequence for all your clips, but only these two are off, then it sounds like they may have been shot differently.
    What mode were you shooting in?
    Is the audio in sync – both before and after the import?
  • Jon Chen
    April 16, 2007 at 6:26 pm
    Hey man i;m having the same problems, see my post for a sample clip. “footage problems! help!”
