Activity › Forums › Panasonic Cameras › hvx mattebox choices
Posted by Jack Lawton on January 14, 2008 at 6:57 pmjust wondering the best mattebox setup for the HVX. I’ve seen the threads about the chrosziel vignetting problems. Is there one that does not cause these problems and would work with a movietube 35 mm adapter? Also, does anyone have any info about the 35mm adapters? which are the best and so on.
Patrick Donegan replied 18 years, 8 months ago 4 Members · 6 Replies -
Emre Tufekci s.o.a.
January 15, 2008 at 5:00 pmWe own 3 chrosziel matteboxes and have this vignetting problem on all of them when filming wide on stock lens. But when filming with 35mm lenses with m2 or letus we get no such problems as the lens diameter and field of vision corrects this. I have to say the build on the chrosziel matteboxes are superior to anything you can buy in that price range. I think they just need to be seated a little better (closer) to the lens.
Emre
http://www.productionpit.com
Boxx Tech PC, dual-dual AMD 2.0,4BG ram,Avidexpress HD w/Mojo,UVW-1800,DSR-25, Adobe Premium CS3.Steadicam OP/Owner.“Creative cow is udder madness.”
Jack Lawton
January 15, 2008 at 5:33 pmthanks for the info. I could tell from the pictures that the chrosziel was a better made item but am concerned because I have only the stock lense at this point. It what point does the vignetting disappear?
Emre Tufekci s.o.a.
January 15, 2008 at 11:47 pm5% push.
Emre
Patrick Donegan
January 22, 2008 at 12:07 pmThere are some relativily cheap ones on eBay.
from a company in india – actually 2 companies in India –
but they seem to be the same one….Anyway, they have a few…..
I am all the way in the middle of the Pacific Ocean
Pekin Azer
January 22, 2008 at 10:05 pmHi Emre, i had to ask you and others 🙂
i just bought the hvx200e and have a funny problem. Only when i do a zoom in, the zoom motor (servo) sound is recorded via the mic. found on the hvx200e…is this normal.. or does my cam have a problem.
Thanks in advance, (şimdiden mersi)
Pekin
http://www.cinemasyon.com -
Patrick Donegan
January 22, 2008 at 10:27 pmWhich mattebox are you using?
Is the ring / seal fitting correctly?
