Activity › Forums › Panasonic Cameras › HVX limit to 8gig P2?
Posted by Pete Sake on June 13, 2007 at 2:41 pmIs the Panasonic HVX200 P2 limited to 8 gigs?
PeterNoah Kadner replied 19 years, 2 months ago 4 Members · 3 Replies -
Chris Li
June 13, 2007 at 2:56 pmNo 8gb limit. I’m using 16gb cards as I write this (time lapse work). You may have to upgrade the firmware on your camera, but that’s it.
Barry Green
June 13, 2007 at 4:25 pmDefinitely not limited to 8GB; the HVX200 will be able to use the 128GB cards when they come out a couple of years from now (and two of those loaded in-camera will give you 11 hours of 720/24pN)…
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db) -
Noah Kadner
June 13, 2007 at 4:58 pmI just did a shoot with 16GB cards on two HVX200’s firmware upgraded and it worked like a charm! We also shot with HPX500’s with 16GB cards. They totally rock.
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
https://www.callboxlive.com
