Activity Forums Panasonic Cameras HVX high audio self noise
  • HVX high audio self noise
    Posted by Spencer Moore on July 8, 2009 at 3:28 pm
    Has anyone else experienced very high audio noise when using the HVX? I’m a sound recordist, so I’m not that familiar all of the menu settings in the camera, but I set up the camera with the switches on the side and calibrate it with tone. The problem seems to be isolated with HVX, no other cameras, or recorders give me this problem. Any ideas? Also, is there anyway to monitor audio without latency?
    Peter Roof replied 17 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    July 8, 2009 at 7:56 pm
    Mic/Line switches are in the font.
  • Spencer Moore
    July 8, 2009 at 7:59 pm
    I’m not that thick. I’ve set everything on the camera correctly, but still noise.
  • Jeremy Garchow
    July 8, 2009 at 9:40 pm
    Do you mean it’s loud or there’s other added noise?
  • Spencer Moore
    July 8, 2009 at 9:46 pm
    It’s like tape hiss, and it’s a very loud hiss at that. It’s from one of a pair of cameras that my clients have been using.
  • Noah Kadner
    July 9, 2009 at 12:39 am
    Only on this one camera- is it possible to be cables, mic or mixer instead? Can you shoot double system instead?
    Noah
    Writing RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the DVX100, HVX200 and Apple Color.
    Now featuring the Lens Adapter Guidebook, Sony EX1 Guidebook,
    DVD Studio Pro and How to Light Interviews.
    https://www.callboxlive.com
  • John Fishback
    July 9, 2009 at 8:23 pm
    I’m not familiar with the 200. We have an HPX500. On the 500 there’s a monitor/alarm control (on the viewfinder side) that, if set too high, adds a lot of noise in the headphone monitoring output. It’s not recorded. You can adjust that control so the sound person gets a clean monitor output.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Peter Roof
    August 18, 2009 at 2:51 pm
    I did experience this on the HVX200 once. Very low level but a high-pitched noise recorded. We proceeded hoping it was low enough to not be a problem. Research found that it was a phenomenon in this model and will only showed up when recording on slot #1. Fix was to have Panasonic do a firmware update.
    Peter Roof
    Alt Gobo MediaWorks LLC
