Activity › Forums › Apple Final Cut Pro Legacy › HVX and Geen Screen HELP!!! I really need the Herd on this one.
  • HVX and Geen Screen HELP!!! I really need the Herd on this one.
    Posted by Robert Bengraff on March 28, 2007 at 8:36 pm
    I will be shooting 5 or 6 “you only get one chance at this” type interviews. and I need to get a flawless green screen key in post. I will be shooting with the Panasonic HVX200. I really would like the 24p cine look and becuse I am compositing I assume I must shoot full progressive. I seem to be getting contradictory advice from my usual trusted sources.
    Should I be shooting 720p/24p 720p/30 or 1080i/24p 1080i/30p or something different all together.
    I am truley confussed and would greatful for the help.
    Thanks, Robert.
    Tom Matthies replied 19 years, 6 months ago 5 Members · 4 Replies
  • Shane Ross
    March 28, 2007 at 9:04 pm
    YOu want the biggest area you can work with, and you want it to mesh with the rest of the 24P footage you are shooting. Shoot 1080p24PA….
    IMHO
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Boyd Mccollum
    March 28, 2007 at 9:56 pm
    Lighting is the absolute key to doing a good greenscreen. The screen should be evenly lit and you want to have good separation between the subject and the greenscreen. Relative exposure between the two elements isn’t too critical – usually within a stop or so of each other – the biggest concern is to control any spill coming from the screen. You should use a backlight on the subject – the quality and intensity based on what will be your background image.
    t[rbengraff] “I really would like the 24p cine look and becuse I am compositing I assume I must shoot full progressive.”
    I think you just answered your own question.
  • Ernie Santella
    March 28, 2007 at 10:36 pm
    If you or your Gaffer have a light meter (Spot meters work best) use that to get a nice flat match to the green behind the person. I wouldn’t shoot without one and my keys are always a breeze to key. Reason being, it’s just one less thing to mess up your key to have it mismatched around the person.
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Tom Matthies
    March 29, 2007 at 1:21 pm
    Another trick I use to get a flat exposure on my backing is to shoot the green/blue screen with my camera, open the iris up a few stops until the zebra stripes appear. If the lighting on the backing is uneven, the zebras will show whick areas are under or over oxposed in short order. Simply adjust your lighting until the zebras are as even across the backing as possible. Easy and no light meter required!
    Tom
