Activity › Forums › Panasonic Cameras › HVX-200A, MP3 recording w/time code
Posted by Bill Donald on May 14, 2010 at 4:36 pmIs it possible to make an MP-3 recording with time code while shooting with an HVX-200A? A client has requested MP3 recording w/time code while shooting w/the 200A. I know I can synch the time code of a HVX-200A to another camera using 1394 but I’m not sure if i can extract and isolate the time code to be included w/an MP3 recording
Greg Sucharew replied 16 years, 1 month ago 6 Members · 16 Replies -
Noah Kadner
May 14, 2010 at 4:58 pmHuh? Why would they want highly compressed audio when you’re already capturing high quality uncompressed audio linked with timecode. If they really want MP3 audio it can be extracted from the footage.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio. -
Bill Donald
May 14, 2010 at 5:31 pmThe client wants the MP3 files w/ time code to be sent to a transcription service. It needsto be done quickly. Is there another method to send audio only w/ time code so it can be transcriped?
Dale West
May 14, 2010 at 6:46 pmBill
Not up to speed with the 200a but IF it has a time code out then it can be done. If not
then no. Unless you can set your 200a’s time code to something like time of day and then use
a lock it box or some other device to drive time code into the recorder. It won’t be frame accurate but close. Or you can try to have the interviews done realtime by the transcription service again setting your
camera time code to time of day according the service’s clock then having them do it live. The cost
is higher but thats about the best you can do.Dale West Video
North Miami, FL
305-892-1201 -
Noah Kadner
May 14, 2010 at 7:44 pmThe HVX doesn’t send timecode out unfortunately. The quickest way would be load each clip into FCP (or whatever your NLE is), then run out AIF (or WAV from a PC editor) from FCP and then convert that to MP3 in another utility. That or shoot with another camera that can be jam synced to another timecode source… Surely they can wait the extra hour or so it would take to download the P2 and output MP3.
Noah
Bill Donald
May 14, 2010 at 8:07 pmUnfortunately the event is in one city, the client is in a different city and wants to start a paper edit. My preference would be to use a better camera. Thank you to everyone for their posts.
Noah Kadner
May 14, 2010 at 9:24 pmah if they don’t need it literally the second you shoot just run off MP3s from your clips on a laptop. It won’t take any time and you can email everything before going home for the day. Anything else would be a lot more costly and save you maybe an hour…
Noah
Bill Donald
May 14, 2010 at 11:47 pmNoah, your idea sounds interesting but I have no idea how to transfer the audio and time code from a clip. My workflow on location does not include FCP. I use a Mac Book Pro w/ Duel adaptor and Lacie rugged hard drive. I drag and drop folders to two separate drives and use PCMS to verify. Is it possible to drag and drop the audio file frm the contents folder to an MP3 recorder mounted on my laptop?
Noah Kadner
May 15, 2010 at 12:54 amYeah you could open those files and extract audio with any of the MXF import plugins for QuickTime such as:
https://www.calibratedsoftware.com/MXFImport_Mac.asp
https://mxf4mac.com/index.php/mxf-import.html
Though personally I’d highly recommend some sort of FCP install on your portable system or you’re kinda shooting blind there.
Noah
Dale West
May 15, 2010 at 12:54 pmMost transcription houses that I’ve dealt with require mp3s with time code on the left channel
and the sound on the right. Their systems read the TC track and with some magic key stroke they
can insert the time code into the transcript. Again I’m totally ignorant of the post process and its something Im working on getting better at but in the end they just need that.In the field I use either a Zoom H4 or ederol R9 and put the TC directly into the left track and the output of the mixer into the right track or I use a Peter Engh box that takes TC and Audio into it and it conforms into a stereo
mini and put that into my mp3 device.And again if its really rush rush we do a live feed, set our time code to the transcription houses time and use a getner box and phone it in. Using that system the producers have literally had the transcript in their email before we finished breaking down.
I think a call to the transcription house might be in order as well. They have probably seen it all
Dale West Video
North Miami, FL
305-892-1201 -
Noah Kadner
May 15, 2010 at 4:55 pmYeah except the HVX200 doesn’t output audible timecode…
Noah
