Activity › Forums › Panasonic Cameras › HVX 200 users… HD monitoring choices
  • HVX 200 users… HD monitoring choices
    Posted by Mitch Ives on March 24, 2006 at 4:57 pm
    To those of you working with the Panasonic HVX200… how are you monitoring the HD streams on an HD monitor? Are you using an Apple Cinema Display… if so with what hardware? If you’re using a Broadcast HD monitor (CRT or LCD) what hardware are you using to connect it to Mac G5 (Decklink, Kona2, etc.)
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    Apple Certified Trainer: Final Cut pro 5
    Mitch Ives replied 20 years, 6 months ago 3 Members · 3 Replies
  • Dan Brockett
    March 27, 2006 at 12:59 am
    Hi Mitch:
    Dell 2405 with the Kona 3 and BMD HDLink HD/SDI to DVI converter. I would like to buy the new Panasonic 17″ HD LCD monitor but have too many other items so we will see how the Dell works out. Obviously not for color correction but for editing, it should suffice.
    Best,
    Dan
    Providing value added material to all of your favorite DVDs
  • Jonathan Palmer
    March 27, 2006 at 9:16 pm
    Black Magic Decklink HD to HD link to 23″ cine display. It’s a great low cost monitor setup. Some people rip it on these forums but it works. Panny’s new 17″ mon is my next step but till then I’m ok.
    JP
  • Mitch Ives
    April 4, 2006 at 6:19 am
    I’ve had a chance to work with the Pannasonic 17″… it is great. I’m definitely getting one. A 26″ is in the offing, but the 17″ is also great for field work as well, so it may be more multi-purpose than the 26″ Panny did a hell of a job with this 17″… it’s the first LCD I have been happy with for HD…
    Mitch Ives
