Activity Forums Panasonic Cameras HVX-200 Transfer from camera to FCP
  • HVX-200 Transfer from camera to FCP
    Posted by Chris Yeo on April 20, 2008 at 10:02 pm
    Hi all,
    I’ve got a quick question. I just got my first ever camera – the HVX-200E. I took some test shots to see what the capabilities of the camera were.
    However we were taught in film school that we could simply import the footage from the hvx-200 to our hard drives and then from our hard drives direct to final cut pro. I’m using the latest version of FCP – 6.02 i think. I’m also using a 16gig p2 card.
    I tried a few methods.
    1) Copying the data direct to an external hard drive using the 1394 function. The data copied nicely but I could not import it with FCP somehow. It read unknown file type and gave me an error message.
    2) I could not find the copy direct from camera to FCP function using the view footage menu.
    3) FCP does not seem to detect the card in the camera as it should and open up with import -> panasonic P2 but it doesn’t on my FCP.
    Any help would be greatly appreciated.
    Cheers,
    Chris
    Chris Yeo replied 18 years, 5 months ago 4 Members · 6 Replies
  • Richard Harrington
    April 21, 2008 at 12:00 am
    File > Log & Transfer
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Tom Klein
    April 21, 2008 at 6:38 am
    Hi Chris,
    make sure you have installed the P2 card driver software onto your computer as well-
    https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/index.htm
    otherwise the camera will not be seen by the computer.
    Cheers
    Tom K
  • Brandon Lima
    April 21, 2008 at 7:43 am
    You need to set the HVX200 on the right settings to see the cards as an external disk.
    Also you need to copy the entire “content” folder from the P2 card otherwise FCP will not be happy. Also you need to go to log and transfer, then “add custom path” then select the folder where you copied the entire P2 card.
    I am copy P2 card right now, it works great.
    -Brandon
  • Chris Yeo
    April 21, 2008 at 5:21 pm
    I’m using a macbook pro laptop and according to the list, it says I don’t need a driver for it.
    However, it says I should get a driver via SD card so the camera can recognize the 16gig P2 card I am using. The funny thing is that I just dropped the card in, formatted it, and did some test shots. I can see these test shots just fine using the viewer in the camera which leaves me wondering whether I should go ahead and update the software version using the sd card or not.
  • Tom Klein
    April 21, 2008 at 11:37 pm
    Hi Chris
    the advice your getting here is correct, may I suggest you read your camera instructions and Go thru the Help file for FCP re ingest P2.
    Cheers
    Tom K
  • Chris Yeo
    April 27, 2008 at 12:40 am
    Hi, log and transfer worked. Maybe it’s an improvement in FCP 6 over FCP 5 – which I learnt on. Cheers for the help nonetheless.
